Otimização de SSD – Parte 1
59 minutos atrás, Baboo disse:
Mas o RAID não estava em funcionamento (2 HDs), certo?
Sim, tinha apenas um HD. Creio que o caso do colega ele também tenha apenas o SSD conectado, já que informa não estar utilizando o RAID.
Tenho 2 HDs na realidade. Um SSD e um Sata. Um disco C - Principal e o D - Secundário.
Storage
        Hard drives
                ST2000DM001-1ER164
                    Manufacturer    Seagate
                    Heads    16
                    Cylinders    243.201
                    Tracks    62.016.255
                    Sectors    3.907.024.065
                    SATA type    SATA-III 6.0Gb/s
                    Device type    Fixed
                    ATA Standard    ACS2
                    Serial Number    Z4ZCPKHL
                    Firmware Version Number    CC28
                    LBA Size    48-bit LBA
                    Power On Count    154 times
                    Power On Time    33,5 days
                    Speed    7200 RPM
                    Features    S.M.A.R.T., APM, NCQ
                    Max. Transfer Mode    SATA III 6.0Gb/s
                    Used Transfer Mode    SATA III 6.0Gb/s
                    Interface    SATA
                    Capacity    1863 GB
                    Real size    2.000.398.934.016 bytes
                    RAID Type    None
                        S.M.A.R.T
                            Status    Good
                            Temperature    36 °C
                            Temperature Range    OK (less than 50 °C)
                        Partition 0
                            Partition ID    Disk #0, Partition #0
                            Disk Letter    D:
                            File System    NTFS
                            Volume Serial Number    90A9FDAB
                            Size    1862 GB
                            Used Space    1489 GB (79%)
                            Free Space    373 GB (21%)
                Samsung SSD 970 EVO Plus 500GB (SSD)
                    Manufacturer    SAMSUNG
                    Serial Number    S4P2NG0M210596T
                    Firmware Version Number    1B2QEXM7
                    Interface    RAID
                    Capacity    465 GB
                    Real size    500.107.862.016 bytes
                    RAID Type    Software RAID
                        S.M.A.R.T
                            S.M.A.R.T not supported
                        Partition 0
                            Partition ID    Disk #1, Partition #0
                            File System    FAT32
                            Volume Serial Number    669C1650
                            Size    646 MB
                            Used Space    64 MB (9%)
                            Free Space    581 MB (91%)
                        Partition 1
                            Partition ID    Disk #1, Partition #1
                            Disk Letter    C:
                            File System    NTFS
                            Volume Serial Number    0EDD64E1
                            Size    448 GB
                            Used Space    368 GB (82%)
                            Free Space    79 GB (18%)
                        Partition 2
                            Partition ID    Disk #1, Partition #2
                            File System    NTFS
                            Volume Serial Number    1A5777E0
                            Size    989 MB
                            Used Space    417 MB (42%)
                            Free Space    572 MB (58%)
                        Partition 3
                            Partition ID    Disk #1, Partition #3
                            File System    NTFS
                            Volume Serial Number    181B6A90
                            Size    14,2 GB
                            Used Space    14 GB (98%)
                            Free Space    199 MB (2%)
                        Partition 4
                            Partition ID    Disk #1, Partition #4
                            File System    NTFS
                            Volume Serial Number    08664480
                            Size    1,12 GB
                            Used Space    651 MB (56%)
                            Free Space    492 MB (44%)
Editado por Mauricio Mendes
Complementar informações
2 horas atrás, dfcbr disse:
Nesse caso o RAID não estava funcionando e eventualmente pode funcionar com AHCI mesmo (Y)
  • Há 4 semanas...
Voltando aqui para um feedback antes do fim do Baboo Forum...
Como tinha postado antes, meu SSD Kingston A400 comprado em Maio/19 vinha com uma queda de  'saúde' de forma muito rápida sem que eu ocupasse a metade dos 240 GB e com um uso doméstico comum.
No meu último post no final de Julho/19 estava com 96% e hoje, 03 de Outubro, já caiu para 90% ... :aborrecido:
Obs.: Qndo abro minha pasta de Download atualmente com 1GB de arquivos diversos, ele abre e a barra superior fica "carregando" de forma lenta até aparecer os arquivos... Vou executar uma otimização neste fim de semana para ver se resolve.
Realmente não comprarei nunca mais esse modelo que por sinal continua vendendo com preço promocional nas grandes lojas.
Lamentável produto esse A400 da Kingston. Nem atualizar o firmware ele atualiza.
Editado por Ronaldo
